Tire rotation
  • June 7, 2010 6:32 AM PDT
    hgsc90 brought to our attention that a photo of my wife's bike showed the front tread to be oriented in what looked to be reversed rotation.  When we first had them mounted I took them back to the mechanic and he pointed out that Avon called for the mounting to be this way and showed me the dual sets of rotational arrows on the tire depicting differing rotation on front or rear wheel use.  hgsc90's comment spurred me to check deeper to see if there had been a mistake in the molding of the tire resulting in the fitment arrows being reversed.  The following article, from Cyril Huze website, is direct from Avon Tires regarding their rotation orientation.  And it was confirmed to me that the tread would indeed look reversed on my set of Avon Roadriders when compared to traditional patterns because of what is written below.  They have designed the channeling to move water regardless of rotation and the tread splice, as you will read below, is what is in consideration with rotation orientation on our set of tires and others like them.
    Good info to know as I always thought it was about water channeling.  And hgsc90, thanks for looking out and speaking up when you saw something you thought may be unsafe!
    Tires Directional Arrows Explained By Avon Tyres
    avontyresBefore we can talk about directional arrows you must first understand a bit about tread patterns. There are many different tread patterns but there is one main reason to have any tread and that is to disperse water. (dust, dirt)
    A tread pattern can be designed to disperse more water by making it rotate in only one direction. Thus, the need for directional arrows. The arrow tells you which way to mount a tire for maximum water dispersal. Another, less apparent reason for directional arrows is the tread splice.
    What is a tread splice? When a tire is manufactured the tread portion of the tire starts out as a long flat strip. This strip is wrapped around the tire and the two ends are cut on an angle so one end overlaps the other rather than having square cut ends.
    This overlapping point or splice offers a bigger surface area to bond together, rather than the small surface area provided by square cut ends. (Imagine gluing your fingertips together, as opposed to gluing along the entire length of your fingers laid on top of each other. Like an angled splice, the overlapping fingers result in a much stronger bond).
    To further ensure the strength of this bond along the tread splice the directional arrow will show you which way to mount the tire so that when the rider is “on the gas”; the acceleration force on the rear tire is pressing the splice together, rather than peeling it back.
    As for braking, 80 % of the braking should take place in the front on most bikes. Therefore, the front tread splice is run in the opposite direction than that of the rear, so when the rider is on the brakes, he’s not peeling the tread splice back.
    If you are using a tire that has a directional arrow for rear rotation only and for some reason you want to put it on the front, make sure it is rotating in the opposite direction so you don’t aggravate the tread splice. Avon Tyres.
  • June 7, 2010 7:54 AM PDT
    Thanks for the post . It appears that new tech is again knocking the old guys knowlege back a notch. Glad that every thing is good. Just one of those old Safty Officer habits, checking everything all the time.. Glad you could get confirmation and guess the mechanic that installed gets an appology and a thanks. Spirit Guide and protect. Howard
