The Digi Sync - Best Digital Throttle Body & Carb Sync Tool
    January 3, 2024 10:38 PM PST
    Many folks aren't aware that periodic Throttle Body Synchronization (Carburetor Synchronization for the older machines) is part of routine maintenance.
    From time and abuse, even cables and linkages can wear and stretch. This results in throttle plates opening at slightly different times from one another. This slight difference has a significant impact on your bike's throttle response. Have you noticed that the bike you bought brand new is now a bit slower at the green lights than when you bought it? You're not imagining that. It's likely because your throttle isn't as responsive as it once was. And, this same issue is also robbing you of your gas mileage.
    This is why periodic Throttle Synchronization is recommended. Now, if you're into racing or stunt riding, that crisp throttle response quickly becomes a safety issue as well!
    It is recommended to perform a Throttle Body Sync at the following times:
    -Periodic maintenance
    -After buying a used bike
    -Whenever your machine bogs down, or throttle response is no longer crisp
    -When racing or stunt riding because in these sports, throttle response is a safety issue.
    -After valve service
    -After servicing carburetors or throttle bodies
    -After cleaning the fuel system
    There are a variety of options out there for Throttle Synchronization. I'll quickly give you a run-down:
    1.) Ignore it and live with the loss of performance and gas mileage.
    2.) Tune it by using only the sound your ears hear. The only mechanics I know that can pull this off successfully have +20 years of experience.
    3.) Mechanical Dial/Needle Gauges. These require troublesome calibration, and the needles bounce all over the place, leaving you wondering just how accurate your Synchronization really is.
    4.) Manometer Fluid gauges. These fluids evaporate and need to be replaced from time to time. Plus, there's the risk you rev your engine too high and suck the fluids in, causing engine damage!
    5.) Professional Digital Carb Sync Tools. These are the easiest to use because they automatically calibrate and give you trustable accuracy that exceeds your manufacturer's specs. However, these come with a "Pro" price tag ranging from $500-$2,000!
    Wouldn't it be great if you could get a Professional Digital Tool for this task without spending a ton more than the Mechanical or Fluid gauges?
    That's exactly why we created www.TheDigiSync.com. We're not business people. We're just engineers who also love wrenching on our own bikes. We, like you, want the best tools, without paying outrageous prices. So, we created this tool for ourselves and shared it with our friends at local bike meetups. That was in 2015, and the response was so amazing that we decided to spend the next 8 years perfecting this thing into what it is today.
    The Digi Sync is quickly becoming "the tool" that motorcycle repair shops love and trust for Throttle Synchronization.
    Need more proof? The Bearded Mechanic (215K YouTube Subscribers) says that after he got his Digi Sync, his old needle gauges became "Wall art".
    We've worked hard to get our starting price down to just $145.95 so that this isn't a Mechanic's only tool. It's intended to be a tool any DIYer can use. If you can figure out how to change your own oil, you can do a Throttle Sync job. We've had many customers tell us that The Digi Sync made the task so easy they were done in 15 minutes!
    While supplies last, use Promo Code "GoFast24" for $10 off.
    Made in the USA
