Penetrating Oils - Which works best on Rusted Nuts & Bolts
    • 13 posts
    May 10, 2017 2:13 AM PDT
    PB Blaster has worked great for me. It's readily available also.
    • 5 posts
    May 24, 2017 4:20 AM PDT
    I have a question about this 50/50 home brew, does the lacquer thinner evaporate thus changing the mix or does  the trans fluid somehow prevent this? I guess you could mix only the amount needed at any given time. Just wondering. Thanks
    May 24, 2017 6:13 AM PDT
    I think if you have it in a sealed container it should be fine... just like storing the lacqyuer thinner not mixed.
    • 16834 posts
    May 24, 2017 11:41 AM PDT
    What Lucky said.
    Just make sure the container is plastic, I use a cheap spray bottle.
    • 19046 posts
    May 25, 2017 6:45 AM PDT
    I mix mine and store it in a used 1 qt Lucas Power steering stop leak bottle. When I plan to use it I shake it up to mix thoroughly and fill this pump oiler. If I keep it in the oiler it tends to siphon out. It will seperate when setting.
