Installing a Tachometer on Harley Davidson FLHR
  • September 22, 2009 10:00 AM PDT
    I bought a tachometer on ebay and want to put it on my 2002 HD Road King FLHR.  The tach has three wires on it... a red, black and, green.
    I assume the red is power, black is ground, and green is for the tach signal.
    My question is, where do I connect the green signal wire?
    Any help is appreciated.
    September 22, 2009 1:56 PM PDT
    Joe,
    There should be a PINK wire somewhere in the headlight assembly, or in the dash under the speedometer. The PINK wire will be capped off since it didn't come with a tach. To be sure that this is the tachometer signal wire, get a voltmeter, connect black to ground, and red to the PINK wire. Start the motor...if the voltage goes up with the RPMs, you got it. I am almost positive that the ONLY pink wire in the speedometer area on a Harley is the tach signal wire.
    September 24, 2009 8:42 AM PDT
    If you can't find the PINK wire, some of the newer years have the speedometer already wired for a speedo/tach combination. Pin #3 on the speedometer should be the tachometer signal wire.
    • 5417 posts
    September 25, 2009 8:24 AM PDT
    Sounds right to me. I put on on my 2002 Road King and used the Pink wire.
    October 5, 2009 10:21 AM PDT
    Hey, did you ever get the tach installed on that Road King???
  • October 8, 2009 3:26 AM PDT
    Yes I did. Found the wire and worked as advertised!
    Thanks for all the input everyone.
