Topics: 128 Posts: 2449
skullshifter wrote...
nightdragon wrote...
My 1995 FLSTN With ove 119,00 miles had the heads done, cam replaced passing gear, right hand clutch left hand shift ( no left leg movement) just put gas in and go.By looking at the picture the shifter looks like it's a long reach.......why didn't you just put a jocky shift on it for a closer reach. Night Dragon It' just looks like that, it's just under the tank next to my knee it took a one grab of the break to rember the switch clutch on the LEFT!!! LOL skullshifter I remember seeing this site (and I forgot where it was) where you could mount a tank shift on the RIGHT side and keep your left hand clutch. If was kind of expensive if I remember. Dragon ______________________ |
Topics: 20 Posts: 416
as far as motor mods go its just about stock. The bike sat for 20 years so all new gaskets new re jeted Keihin carb, new cluch plates all new cables, push rods and covers, drag pipes, re built magnito. new oil lines and a bunch of other stuff I cant even rember. She still has orgional pistons and has 115 lb front piston and 110 lb back piston of compression. Not bad for 41 years old. As you can see from the before and after pics I did some other mods to the bike |
Topics: 0 Posts: 3
Mine's got a 100" square heart from S&S. A heavy duty clutch, primary and final belt. I don't wash mine much either. It's got 97,000 miles on it. I don't abuse it, but it'll run 85-90 ALL DAY on trips without so much as a hickup even with my fat ass and a hundred pounds or so strapped to the back. Fuel economy: about 36 MPG. |
Topics: 1 Posts: 6
Cam, V&H shortshots and a re-map. Runs and pulls strong. More fun to ride now. |
Topics: 139 Posts: 2778
bullmoose wrote...
as far as motor mods go its just about stock. The bike sat for 20 years so all new gaskets new re jeted Keihin carb, new cluch plates all new cables, push rods and covers, drag pipes, re built magnito. new oil lines and a bunch of other stuff I cant even rember. She still has orgional pistons and has 115 lb front piston and 110 lb back piston of compression. Not bad for 41 years old. As you can see from the before and after pics I did some other mods to the bikeMaybe it would have been easier to ask "What haven't you done to your motor?" ______________________
Topics: 20 Posts: 1819
I was thinking about installing the Night Rider XIed O2 sencor pig tails to richen the 96 tc on my 07 road king what do you all think. ______________________ |
| Forum Home | Browse Latest |
Moderators:
HDBeech, AdventureGirl, RexTheRoadDog, debrajo62, highrisk, RevBigJohn, Lucky, CycleFishAdmin
